Hand Held Scanner?
johnsawyer
Car: 2000 Infiniti QX4
Can i use any ODBII scanner to get codes off my 2000 infintiy QX4, or does it have to be very specific?
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
any works. a friend got one off ebay for $40 and it worked on my 99 q
W O T
Car: 2001 Infiniti Qx4
"MOST" work, some are cheap units, and dont even work all the time, dont connect properly/ cant read the codes.
Some are very vasic, some just tell you the code, some tell you the code and let you clear it, which is all you really need with the internet.
But the more expensive ones give more detailed info that a mechanic would probly find helpful
