hand cranking engine
spider_slayer
Car: S14 240SX
S13 240SX
is there a specific direction in which to crank the engine? i was reading through the fsm and couldn't find any specification. granted i didn't read every page... but i'm still curious.
bdrifta
Car: 1992 Nissan 240sx sr20det
if i remember correctly, facing the engine from the front of the car...its counter clockwise...
spider_slayer
Car: S14 240SX
S13 240SX
let me rephrase my question... does it matter which way you crank?
LasVegas240sx
Car: 1991 Nissan 240sx SE
I'm not saying you can or can't but when I did the waterpump on my car I turned the motor both ways. The way to turn it is counter-clockwise like stated above.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Well, with the stock mechanical fan on, it suggests you turn the engine clockwise.
spider_slayer
Car: S14 240SX
S13 240SX
Silvia007 wrote:Well, with the stock mechanical fan on, it suggests you turn the engine clockwise.
was this in the fsm? wanna give me a pg number? and also...why would the stock fan that is attached to the water pump matter which way you crank?
ILikeMy240sx
Car: SR Power
counter clockwise? wtf dude...
Clockwise because thats the way engine spins..
deCksy
ILikeMy240sx wrote:counter clockwise? wtf dude...
that's what i was thinking...
Silvia007
spider_slayer wrote:was this in the fsm? wanna give me a pg number? and also...why would the stock fan that is attached to the water pump matter which way you crank?
Well with the stock fan on, when you turn the engine counter clockwise, the fan would be pushing air out the front of the car and not pull air in from the front of the car.
jt15833
Car: 95' 240SX
yea aren't most engines clockwise? were are you getting this counter clockwise from?
spider_slayer
Car: S14 240SX
S13 240SX
maybe he means when facing the engine counter clockwise? i am assuming all of you guys mean the engine spins clock wise, so when facing it you would have to crank counter clockwise correct?
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Facing the engine from the front of the car it is clockwise, but it doesn't matter what way you turn it, as long as the chain tensioner is still installed and released.
chad_KAT
Car: 98 Red S14
wow just wow to this thread
NoStickers
Car: 1991 240sx w/ sr (RIP)
1989 240sx w/ ka
1996 240sx donor car (coming soon)
bah I turn it clockwise and never had a problem...
jt15833
Car: 95' 240SX
spider_slayer wrote:maybe he means when facing the engine counter clockwise? i am assuming all of you guys mean the engine spins clock wise, so when facing it you would have to crank counter clockwise correct?
whaaaaaaaaaaaaaaaaaaaaaaaaaaaat?99% of the time youll hand crank the engine itll be from the front by the crank pulley. since the motor spins clockwise when looking at the crank pulley, spin it clockwise. this isnt a difficult concept to grasp
spider_slayer
Car: S14 240SX
S13 240SX
LasVegas240sx wrote:I'm not saying you can or can't but when I did the waterpump on my car I turned the motor both ways. The way to turn it is counter-clockwise like stated above.
this is what i was replying to cheif.
i hand cranked clockwise simply cause the timing mark on the right is btdc. thats all i went off of. i was jsut making sure cause i couldn't find anything in the fsm/bible.
