Ok, So I broke the cable to the right rear caliper. Now I have no hand brake. I Managed to get the new cable installed onto the caliper and routed through the subframe to the T-Bracket that connects the two rear cables with the front one. However, I cannot figure out how to connect the cable to the T-Bracket.
The bracket appears to be a single piece of stamped or pressed metal with no obvious method of removing the cable.
Ideas?
