so did you check the anchors to see if they were seated properly?JdrifterCA wrote:after braking hard a few times, it got more tension, but still loose.
Like adrian said, if that anchor is not attached or is loose then you won't have any or much leverage on your ebrake.adrians_s13 wrote:
Also, there's an adjuster on the bottom of the hand brake lever. iirc, its like a 10mm nut that can tighten the cable.
