Hanabi quick questions.
SlidewaysScott
Car: 1990 240sx hatch, 1995 240sx sr20det
Have a chance to buy Falken Hanabi rims with tires, 18x8.5 +38. Does anyone know if they will clear z32 30mm brakes for sure and any other clearance issues other than fender rolling?
babowc
Car: 240sx
it should clear..then again, tahts a bad offset... why going with 38 on a rwd?i understand its 8.5 but still.. 38 is a bit high
SlidewaysScott
Yeah I know, I wish they were like 30-35 offset. But it's to good of deal and everything. Plus I need rims ASAP since I just did 5 lug conversion and z brakes. And they are from a friend. Any clue how they would sit? haha I'm hoping they arent like sunk in or stick out
naed240sx
Car: .....
If that is for a 240sx, there is no way it's gonna fit on the front.
dousan_pg
Car: 1995 240sx 1991 infiniti q45 1993 nissan 240sx
offset has NOTHING to do with brake clearance
argue w/ me all you want, i know this for a fact.
crzycav86
Car: 93 Nissan 240SX KAT
dousan_pg wrote:offset has NOTHING to do with brake clearance
Agreed.
However, a picture of the wheel and the specifications will give a better guess.
crzycav86
Anyway, yeah that particular size will clear z-brakes.
babowc
Car: 240sx
i had the idea that anything over 16 will clear z brakes.. am i wrong?
naed240sx
Car: .....
babowc wrote:i had the idea that anything over 16 will clear z brakes.. am i wrong?
Wrong. If the spokes are not far enough away from the mounting surface, they will hit the caliper.
babowc
Car: 240sx
oic.. then thats the spoke design.. but not offset?
crzycav86
Yeah, you're wrong.
My stock 15" alloys cleared the brakes diameter-wise, but I needed spacers so that the spokes would clear the caliper. That's the issue here.
I verified with a website that these rims fit on a 300zx, thus clearing the brakes... but none of the other sizes will clear according to the site, only the 18x8.5+38.
babowc
Car: 240sx
ooh.. so how much of a spacer did you need?i assume somewhere around 10mm?
crzycav86
Depending on which version of s13 SE rims you have, you can clear the front brakes with a 5mm spacer and stock wheel studs.
Rear z-brakes are pretty sunken in, and they do not require a spacer.
nismofly
Car: 89 Nissan 240SX Hatch
that size wont clear coilovers in front without a spacer anyway, if youve got coilovers you just solved any brake clearance issue you may have
crzycav86
nismofly wrote:that size wont clear coilovers in front without a spacer anyway, if youve got coilovers you just solved any brake clearance issue you may have
True, but not everyone wants coilovers.
naed240sx
Car: .....
crzycav86 wrote:True, but not everyone wants coilovers.
The sizing he is looking at won't even clear a shock setup on an s13. Not sure about s14.
SlidewaysScott
woah woah no i know offset has nothing to do with clearing z brakes. I was just asking if anyone knew if this particular spoke design/wheel does. And you think it wont even clear my shocks at all? hmmm alright thanks for the info. I'll be checking them out tomorrow now anyways that i know they will clear z brakes and everything. Thanks
crzycav86
naed240sx wrote:The sizing he is looking at won't even clear a shock setup on an s13. Not sure about s14.
Are you sure? I think it would.
SlidewaysScott
I dont know, I'm thinking maybe I can fit them. I just talked to a dude I know who has 20x10's on his s14, and coilovers and says he clears. Said he runs 5mm spacers just to be safe and he had 18x8.5 +38 on his car before and didnt have a problem....I'll see how this goes tomorrow. fingers crossed
Valley
Car: 00 celica gt-s 89 240sx hatch
rim, yes, tire, no.
using a 225mm tire, it would be making sweet love to the stock shock assembly
BlackFlag_s13
Is this local to you? Test fit them, the only way to be sure... or just run 10mm sandwich spacers, thhey'll help clearence and flushness
FerretsCanDrift
Car: 95 sx
+1 You said that these are your friends wheels so test fit them. It might also help if you posted what size tires are on them
Jookmasta
hey is this for an s13 coupe? if so, would u mind posting pics? ive been looking forever and ever for pics of an s13 coupe with hanabis on em
babowc
Car: 240sx
indeed.. i'd love to see how it looks as well.
naed240sx
Car: .....
Jookmasta wrote:hey is this for an s13 coupe? if so, would u mind posting pics? ive been looking forever and ever for pics of an s13 coupe with hanabis on em
It's for his s14. By the way, 18's don't really fit functionally on s13 front.
