Sounds obvious but maybe check out the Haltech website. They have owner forums and a really good support section. Also have you r tried self tuning. If you have the right O2 sensor and your wideband hooked in the 1000 can self tune. Maybe this will help build you a base map and you can fine tune after you get the kinks worked outLuckyX2 wrote:Hey guys, I made a thread over in the tuning section here: haltech-1000-sr20det-t534465.html but the tuning section gets very little exposure so I thought I'd post here also.
Basically I'm trying to tune my Haltech Platinum 1000 but I am having a rich condition with any sudden throttle input. I'm thinking it could be my transient throttle or injector angle settings but I'm not sure so I'm here for advice.
I would appreciate any advice and/or tunes and settings that could be shared to help me get started with my haltech+sr combo.
Thanks!
That's the transient throttle enrichment I'm taking about right? That's what I'm asking aboutSeishuku wrote:Rich on throttle tip-in is from bad settings on acceleration enrichment (or whatever haltech calls it).
Yeah, I have the base fuel map pretty well taken care of or so it seems since it will get good afr's if I gradually up the throttle. Anything sudden and it sputters though so I'm thinking the transient throttle would need to be adjusted. Also since I have poncams do I need to adjust the injector angles?rc1honda wrote: Sounds obvious but maybe check out the Haltech website. They have owner forums and a really good support section. Also have you r tried self tuning. If you have the right O2 sensor and your wideband hooked in the 1000 can self tune. Maybe this will help build you a base map and you can fine tune after you get the kinks worked out
