I ordered the Haltech E8 system for the 180SX. I ordered it from Tweakit on the 20th and it got here in about two weeks. The kit I ordered is herehttp://
www.tweakit.net/shop/pr...=1010I also ordered the air temp sensor and the injector plugs. I already had a 3BAR MAP sensor and will use the CA18 OE water temp sensor. Here is what came.I was very pleased with the customer service, I asked about getting the injector plugs and a rep directed me to the items and I just added them and the they shipped them together with the ECU and harness. The speed was really good when you consider to get to me it had to go to california where the military picked it up to ship it to my PO Box in Japan. I opted for the flying lead harness as it is my intention to lose as much of the factory wiring as possible. They aren't messing around either, the wire bundle is 8 feet long! They have tied off the wires into clearly-labeled sections for me, cool!
If someone just wanted to plug and play there is a great option right here.
http://www.tweakit.net/shop/pr...=2296the E8 is the middle-rank system, there is the entry-level system the E6X here in a flying lead configuration
http://www.tweakit.net/shop/pr...id=91If you are really going for broke they have the E11, Haltech's top-rank systemplug and playhttp://
www.tweakit.net/shop/pr...=5919flying leadhttp://
www.tweakit.net/shop/pr...d=529
If you are thinking one of these might be what you are looking for I invite you to check Haltech's site and look at what they can do.
http://www.haltech.com.au/ecu_comp.htmIt will be a while before I get to installing and tuning this unit, I have no opinion thus far but I definitely give Tweakit a thumbs up!
