johngriff »
https://forums.nicoclub.com/johngriff-u30588.html
Wed Dec 23, 2009 8:49 am
No EMS does a good job with the 80-90's nissan knock sensors, they are garbage.
Sounds like you bought scooters setup.
Lots of KA's run Haltechs, just not allot of people posting problems with them like the aem.
As far as your Q about the LS1 coils.
You are going to want to use ISO standard plug wires to connect to the coils, so make sure you have ISO tips on the plug wires, and ISO plugs to push the plug wires onto.
Or you could make your own wires, and go ISO on the coil, then JIS the rest of the setup.
Make sure the dwell is set correctly.
What other sensors did they give you to hook up?
John
Also, We make a plug and play harness for the E8 to the S13 KA. You just remove the factory ecu harness.
