Haltech e11v2
richracing
Car: 280z
Anyone here running one? I will be starting to install mine in a few months and am trying to find out as much info as possible before i start.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Best to check the Haltech Forum and pray someone will respond.
robbie2883
Car: 1998 RB25 Kouki
hey marc, though were trading that out with john? decide not to? let me know if i can be of any help to you.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I'd recommend reading the manuals posted on Haltech's site first so you know basic startup procedures. Also, track down all the necessary wiring diagrams ahead of time because the sensors, etc do not typically come with them.
If you have questions along the way, just start post questions here and we'll help you out. I know there are several guys here who are knowledgeable and who helped me get mine up and running.
Ramius83
Car: 1995 240sx SE
I ran a Haltech E11V2 on my RB26 a few years ago. I used the patch harness so it was plug and play into the OEM harness. All you have to do is run an air temp sensor and a map/baro sensor and that's it. Use a base map that you can get from haltech for free and get it tuned.
I had no problems with it. It was easy to tune. The only thing that sucked was it didn't have USB, it only ran old serial. So you have to get a USB to serial adapter.
richracing
Car: 280z
Thanks for the feed back guys. I wish there were diagrams out there for how to wire in the ignition and injectors, but i'll figure it out
richracing
Car: 280z
Robbie, we were going to trade but decided not to
richracing
Car: 280z
So I've got everything wired up... tomorrow I will fill up all of the fluids, and then attempt to set up the Haltech from scratch since I don't have a base map.
Darius
The software comes with base maps. Why would you try to start it from scratch?
richracing
Car: 280z
well, i didnt know the software came with base maps. i have never used haltech...
Darius
Yep, when you install the software, the base maps are loaded under the Haltech folder. Then, when you go to create your tune, start by opening the appropriate R33 tune (MAF vs MAP). Then, make the adjustments you need in terms of injector size and dead time, etc. As long as your injector dead times are close to correct, it should fire off without a problem and you can tweak the base fuel map to get it to 14.7 or so at idle.
You have a wideband wired into it, correct?
richracing
Car: 280z
I am using an Inovate LC1 wideband. I plugged the haltech to my laptop using a serial to usb adapter, but says Haltech disconnected. On my laptop I am using windows 7 32 bit through VMware manager. No idea right now as to why it wont read, but I called it a day as my frustration level was at "f*** it"...
richracing
Car: 280z
I think I just need to set up my com port for the usb/serial adapter.
richracing
Car: 280z
where is this haltech folder you speak of??? i dont see it. Anyways, I quit. I don't have a 32 bit computer, and it was a nightmare dealing with the virtual 32 bit OS on my pc. So I quit until I get a 32 bit laptop, or until someone else comes and tunes this thing.
richracing
Car: 280z
ok, so i found the basemaps under "load all" but there is only STD maps and 1 toyota map... so how can i get this s2 rb25 map?
