Hey thanks, I'll pm you with my email if you could send the tune there. I know it's not going to work exactly for my setup but I would just like it for some kind of reference.
I used the Sr20det base map supplied by haltech and pretty much just trimmed 30% off the fuel across the board since I have 550cc injectors instead of the stock 370cc's. I also changed the dwell time on ignition to 5ms since I'm running LS2 truck coils. Other than that, basically just some IAC tweaking and set up of the wideband and O2 control has been done.
It's the stock tps, Innovate LC-1 wideband (calibrated in the ecu to 22.4/7.4 max/min afr), haltech internal map sensor, haltech air-temp sensor, stock coolant sensor and haltech boost control solenoid. Am I missing anything?
Oh and a more complete list of mods would be:
t28 turbo, 550cc injectors, adjustable fpr, poncams, large greddy fmic, full 3" exhaust, isis tubular exhaust manifold, ls2 truck ignition coils, mishimoto rad with electric fan, titanium valve springs, solid lifters, hand porting of the head by myself and whatever other little details I may be forgetting...
Also, I'm having one hell of a time trying to get my tach to work. I have this tach, here:
http://prosportgauges.com/amber-white-p ... meter.aspx Using the dpo1 output on the haltech unit, set to 12v tach, it's not working. I also tried using the coil ground as signal, the 180 cas line as signal and even bought a stupid $50 tach pickup from MSD and that doesn't even work. Oh and I tried doing the conversion of the stock sohc tach to dohc tach by running a line from the TAM signal to the positive coil terminal and still, nothing. Any ideas?
