YoungCoupe »
https://forums.nicoclub.com/youngcoupe-u190540.html
Sun Nov 03, 2013 1:00 am
From what I've heard, they just aren't made to high standards, things such as there being a gap between the reflector bowl and shroud, so you can see some exposed wires. Little things, I haven't heard anything terrible about them. If you are on a budget, these are definitely the way to go to get that look.
That being said, going custom is much better. There are companies and people that will customize your headlights however you want, like Dangeris, a member here on the forums. They do cost quite a bit more though. If you're brave, you can tackle the project yourself like I did. If you go this route, I recommend doing plenty of research first, especially on how to get your headlights open. I think 07-09 headlights are semi-permasealed so they will be harder to open.
