Halo fogs...
All things Altima Coupe.
RicerX
Car: '20 Titan Pro4X
wildcat08
Car: 09 Nissan Coupe S 2.5 CVT
09 Nissan Rogue S AWD - traded
09 Nissan Murano SL
I just ordered those earlier this week. I should get them on Wednesday and the plan is to install next weekend. I've been wondering if there will be a way to turn the halos on independent of the H11 bulbs, or if I'll need to modify the wiring a bit. I'll try to take some better pictures of the harnesses and stuff that comes with it. I'm not pre-wired for fogs so I'll have to run all the wiring back and put the switch next to the trunk release.
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
The halos come on with the fogs as there is only 1 switch included. You will need to modify the wiring / add another switch.
RicerX
wildcat - do you have oem fogs already or will this be a clean sheet install?
wildcat08
09 Nissan Murano SL
I don't have fogs. 2.5S, convenience package only. Sucks about the switch. I was thinking about tying the halos to the relay for my HIDs so they will come on whenever the headlights are on and having the switch for the fogs on the dash.
obstacle
Car: 2010 Altima Coupe 2.5 MT Winter Frost
i bought these (http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0512758069) in december, but its been too cold to install outside.
ebay seller hdcautosports
they have a switch, and you can control both the halo and the bulb separately (so the seller claims). I'm not expecting much from these being they were cheap.
a several members have had mixed reviews on ebay fogs in general. For some, they've lasted and work good, but others have had them burn out after 1 month or so.
If anything, i'm sure you can replace the bulbs and what not if that were to occur.
RicerX
I'm wondering if these things will just plug right up if you already have fogs. That's the situation I'm in at the moment.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
they shouldn't. the switch has 2 buttons, one for the fogs and one for the halos. oem stalk is only on or off. i suppose you could just wire them together and have the fogs and halos come on and off together only, but you'd also have to get the connector to attach them to the oem harness
obstacle
XenonSE-R wrote:I'm wondering if these things will just plug right up if you already have fogs. That's the situation I'm in at the moment.
these wont plug in even if you are prewired. thats why they come with a wiring harness
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Yes folks, Im search bombing.
Does anyone have these projector fogs installed and do you have pics of the light ouput?
EDIT: Nevermind guys, found it. For anyone else who was curious: post5788214.html?hilit=projector%20fog%20light#p5788214
