ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Tue Aug 29, 2006 3:29 am
The information in your post and your title is not easy to understand.
As mentioned above, it is not clear whether you are asking about MBC's ability to make more boost or your car's ability to make more boost.
Anyways, do you still have the stock fuel pump? If so, I would actually bring down the boost. It's risking it even with stock SR setup. I would not go any higher than what you have now.
Also, MBS's capability to reach certain amount of boost really depends on the base boost set by your wastegate actuator. So basically, depding on the spring mechanism in your MBC, you can either add X amount of boost to your base boost or add X+Y amount of boost (Y being the extra amount by going stiffer spring in your MBC). So as you can see, the MBC and the wastegate actuator combined determines the highest boost you can theoretically run.
