HALLELUJAH! I STAND BEFORE YOU RESURRECTED.
captluigi
Car: 1996 Qt
the rumors of my demise have been greatly exagerated. it's been a while since i last posted so i guess the mods thought i had ceased. just been fishin, that's all. i attempted to log on and was denied, but now i'm back. the question here is, how is the heated switch panel removed? can not seem to find that lil'bit of info in the fsm.
goody90q45
Car: 1992 Infiniti Q45 (sold)
It's held in place in 4 places- 2 across the top edge and 2 across the bottom edge. All 4 are about 1 1/2" from the ends. Put a skinny screwdriver in one of these 4 spots and gently wedge between the plate and the trim. Should pop right up. Welcome back Luigi.
captluigi
Car: 1996 Qt
that worked perfectly. thanx
StarPD
Car: 2005 Q45
captluigi wrote:that worked perfectly. thanx
Man, you guys are a lot braver then I am.Every time I try something like this, I either break a clip or two, scratch or cut the escutcheon, or both. I can fix mechanical stuff like I knew how, but body and trim work escapes me. I gots ta pay an exert to do that kind of work for me.
I envy you.
db_autotek
Car: 1994 Q45t black & 1993 Miata racer. Previous: 1994 Q45, 1992 Q45.
Non heated Q's have the coin tray, so I just grab mine firmly and yank the cr@p out of it, in an upward motion. Since I have no wires to worry about. Always works for me, no clips broken.
captluigi
Car: 1996 Qt
i used a plastic(credit)card. no scratches, no woorries, no problem mon.
