bruinbear714 »
https://forums.nicoclub.com/bruinbear714-u1106.html
Tue Aug 05, 2003 7:54 am
[quote=" :: orion :: The "Hacked MAF" is a replacement for the S-AFC, if anything.
The best way to approximate a hacked MAF for 550s will be to use 2 identical MAFs and 2 filters, with a Y-pipe. Plug one MAF in, leave the other untouched. So you have injectors twice the size, and the ECU reads half the air...almost a perfect compensation, in theory.
Personally, I wouldn't use it for more than ~250rwhp (or with anything more than 370s), or about 9psi from you T3. I was running lean with 8psi from a T3/T4 with a hacked MAF and 370s...
And with the turbo ECU my spool is noticeably better, off boost driveability improved, and the car is smoother across the board...you can't replace proper timing and fuel control.
Later - Brian[/quote]
We have a winner!!!! Except for one thing....
Suppose you have the stock setup, 1 MAF, 270cc injectors. For simplicity, let's say your injector duty cycle is 50% for a MAF reading of 1V, and duty cycle is 100% for MAF reading of 2V.
Now, if you have a Y-pipe with only 1 MAF plugged in, you will get half the reading. So instead of reading 1V, you now read 0.5V and that will drop the duty cycle to 25%. Doubling the injector size from 270 to 540cc (550cc is what's available) will correct the amount of fuel entering the cylinders.
Now this sounds like a perfect solution, but the fault here is that it assumes the system's behavior to be LINEAR. However, the MAF's response may be linear up to a certain air flow rate. Using a Y-pipe with 1 MAF connected may allow the system to operate in that linear region and never reach the non-linear region, in which case it would work perfectly.
