ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Fri Oct 06, 2006 8:29 pm
That's a good idea. Better than the microswitches based on throttle angle. If it works that way, that's what I'll do (maybe I'll learn a few things about hobbs switches too). I'm of course fond of the 385 series too. Basically an overgrown clevor from the factory (cleveland style heads, windsor type block). Of course, why stop at 429? I'll probably start with a simple 460 in the neighborhood of 550hp. I've got some 4.3" stroke cranks and misc blocks/heads too. No emissions laws here, that's entirely correct. There's not even a visual check. I like the VH45 too, but wish it would have been up-sized in every aspect to be a VH85. Of course, with a stock 429 block and billet crank, 600" is possible. What would that be? Somewhere around 10 liters. Top it with some TFS A460 heads and it'd be an awesome street motor. A smooth and reliable 800hp and 900ft/lbs wouldn't be too difficult. Of course, that's kinda overkill, even for the mighty Q (in my opinion). I'll be happy if it'll keep up with an '04+ Viper. That'll require a small stroker motor, but that's pretty easy and cheap to build. Of course, when I say small, I mean 557" or 545". I hope the driveshaft (gonna need to be cut and adapted to the ford trans output) and rear end are up to the task. The A/C compressor is shot, the active struts are leaking, and the trans is starting to be slow shifting in the cold. It's time for an upgrade to more muscle. Basically, I want something close to a C5 vette but have $20K of student loans to pay back. If I can save $20K by not getting a loan for a vette, I'll be quite happy. I know that this Q/ford hybrid will get less mpg than a C5 and won't brake/corner quite as well, but the acceleration and ability to carry passengers/luggage will hopefully make up for that.
