Had some damage to my g37x last night, need some guidance
clouser
Car: 2012 g37x sedan
I was out driving last night in a pretty rough rain storm, and I must have bottomed out a bit in a deep puddle because I started hearing a dragging sound. This morning in the light, I could clearly see some plastic cover that was near the front axle was torn up and dragging along. I *think* it was one longer piece held on by one bolt on each side before getting split, not two separate pieces of plastic, but I cannot be sure.
I am not sure what this part is to replace, it's intended function, or how critical it is.
Here are a couple pics I took, I can get better ones if needed: http://imgur.com/a/wZjWw
2012 G37x Sedan
Thanks for your help
telcoman
clouser wrote:I was out driving last night in a pretty rough rain storm, and I must have bottomed out a bit in a deep puddle because I started hearing a dragging sound. This morning in the light, I could clearly see some plastic cover that was near the front axle was torn up and dragging along. I *think* it was one longer piece held on by one bolt on each side before getting split, not two separate pieces of plastic, but I cannot be sure.
2012 G37x Sedan
Here is a photo of the fiberboard shroud taken from my 06 G35.
It is possible that not all of the fourteen 10mm bolts were replaced during oil changed or it just got ripped up when you hit water.
Not a good idea to drive without it as it protects the lower engine as well as preventing water from splashing up into electrical connections.
My advise is to get it replaced.
Telcoman
AWGD8
Car: 2008 EX35 AWD JOURNEY
The one cover closer to the o2 sensor which you took picture at is not part of the front underbody cover as pictured by telcoman. There is a small separate cover for that if I am not mistaken. Do you see the cover as a whole piece from under the front bumper towards the rear of the o2/ catalytic converter cover? Or 2 separate ones? One big and one tiny ones that covers a bit for the rear 02 sensors?
clouser
AWGD8 wrote:The one cover closer to the o2 sensor which you took picture at is not part of the front underbody cover as pictured by telcoman. There is a small separate cover for that if I am not mistaken. Do you see the cover as a whole piece from under the front bumper to towards the rear of the o2/ catalytic converter cover?
It looks like a smaller piece, connected from very close towards the front bumper (maybe a foot away?) and ends right after the front wheel well.
AWGD8
AWGD8
Maybe this one ?
http://www.ebay.com/itm/New-Engine-Spla ... fc&vxp=mtr
http://www.ebay.com/itm/New-Engine-Spla ... 4897.l5666
Just verify with infiniti parts dept. get the part# and google it to find a better price.
clouser
So I finally got the part removed today, here is a pic here: http://i.imgur.com/CgsFMvk.jpg
Would this be the bell housing? Is it abnormal that it was held on by only 3 screws, considering there were so many drilled holes in the plastic? Wondering if the place that did my oil change didn't put it back on right...
clouser
AWGD8 wrote:Maybe this one ?
Looks like you were right with this part: http://www.ebay.com/itm/New-Engine-Spla ... fc&vxp=mtr
Here is the part off the car: http://i.imgur.com/CgsFMvk.jpg
