Had my car back on the dyno......
datsunboy
Car: Datsuns
last dyno run was 178HP at 7psi on standard turbo.new dyno run was 221HP at 11psi on GTiR turbo
it has not been tuned yet, we tried a run at 14psi, but it started to detonate.
also the AFR's are very rich.
datsunboy
Car: Datsuns
and the AFR and Power
CA19DET
get some fuel management and lets see if you can crack 280whp ay ~16psi, i am sure it feels allot better now and only more to come,
JDMSIL80
What other mods do you have in the car?
Scooby24
Car: 01 BMW 330CI
Very nice...yes way too rich on AFR.
Dependent upon timing, knock, egt's etc I would shoot for around 11.2:1 or so....smoothing it out and with that AFR you should be around 240 or so on that same boost
float_6969
Yea, that AFR, is killing your power. If you can get some fuel and ignition tuning done, you'll be good to go! What other supporting mods do you have?
datsunboy
Car: Datsuns
yeah the guy said there was a bit of power hiding in the AFR's.
I'm buying a wideband next week for myself so I can do a bit of road tuning to reduce dyno costs.
engine:VR4 injectorsVR4 intercooler2" pres bent intercooler pipes3" mandrel exhaustGTiR - T28 Turbo @ 11psiGizzmo electronic boost controllerRB20DET MAF ( I have a Z32 one....havn't got around to installing it yet )pod filterSR20DE Throttle body
and thats about it.....other than having no power steering or aircon.
float_6969
What are you using to control the injectors and MAFS?
datsunboy
Car: Datsuns
standard ECU re-chipped.
