I recently did the same thing, only had to heli coil the bolt hole afterwords because I damaged the threads in it when the bolt broke originally.ADAMHU wrote:i just snapped a manifold bolt and has to remove it...its actually very easy...
1=buy a set of bolt removers..they look like reverse thread drill bits..sort off
2=drill the reccomended hole into the center of the broken stud.....yes it can be done.....
then just insert the boklt remover and unscrew the broken stud....easy....
i did this with the head still on the car..and the with the turbo even in the way
