Pathfinder3.5 »
https://forums.nicoclub.com/pathfinder3-5-u159719.html
Tue Jan 31, 2012 4:50 pm
Had a little accident involving some black ice and a curb a few weeks ago. I nailed the curb at about a 60 degree angle in the front passenger side which led to a nasty 180degree smack on the rear passenger wheel. I pretty much demolished my lower A-arm up front. Anyways, everything is fixed and fine(New LCA and Balljoint). Both my rims on that side are pretty mangled...Not bent, just severely gouged. Thats okay cause I was planning on plasti-dipping them in the spring anyways.
I got a Alignment just to be sure everything would be fine(Needed one anyways). Ever since the accident i've heard and felt a loud knocking sound/feeling in the rear end and the steering wheel was on the slightest angle to the left(thought it was a bad alignment). I figured it was either the spare tire or my ball and hitch I have sitting in the rear storage compartment. After removing the hitch attachments and checking the spare tire, the noise was still there. I ended up taking it into my work and putting it up on a lift.
This is where I got shocked. The rear driveshaft is mis aligned with the rear differential, the passenger side strut is pointing straight up, driver side strut is on an angle. My Torsion/Sway bar in the rear has a bend in it that was hammered out when I replaced the A-Arm. Turns out that my entire rear end has shifted over by about half an inch. This would explain the angle of the steering wheel. The noise is coming from where the Torsion/Sway bar attaches to the body. The bolt that holds it in the mount is just flopping around.
At this point, I want this thing to ignite itself on fire. I just had to spend $180 on a brand new DRL Module and another $360 for the Lower Control Arm and Balljoint. The check engine light also illuminated itself as it does monthly. I love this truck alot but it's starting to get a bit out of hand. I understand that this problem is my fault but would it even be worth to fix? I seemed to have done some damage somewhere. I dont believe a new Torsion/sway bar would even fix this. My Mechanics basically said I would have to take it to a Body Shop to see what they say.
It's going in for the rust recall tomorrow. Hopefully the thing gets written off. Do you guys think its worth fixing? Could it just be the Torsion bar?
Thanks!
