How much do the hockey pucks raise the engine? I need to clock this bugger about 1" toward the passenger side.Chezedik wrote:My $.02:
It is a good looking mani (unless you got rid of the SSAC) and the hockey pucks do work like a dream. It just takes 5 pux and 2 bolts. Total cost for new motor mounts = about $7.50.
How would re-indexing the turbo flange preload the valvetrain?WDRacing wrote:I dunno, doesn't that preload the entire drivetrain? Not to mention that mani is so UGLY.
I'm a bit skeptical about this product. They don't mention it's construction (i.e. what's it made of?) and it's pretty tall. That would definitely take up space in the engine bay, and might cause clearance issues. I don't think a large T3/T4, with that adapter, would fit under the T2 bottom mount.tvmendoza wrote:what about these adapter? http://cgi.ebay.com/ebaymotors...ZWDVW
Is it a good idea or is it better to weld????
Even if I use a really big hammer?crzycav86 wrote:The SSAC t2 manifold is a tight fit even with the t25.
I don't think WD's idea of just hacking off the t2 flange and welding/porting a t3 will work out too well.
Already did that with the previous turbo. LOL I know EXACTLY what the problem is. This new turbo is a Garrett internals unit with cheap-o chinese housings. So, the offset (side to side, not front to rear) is a bit different.klattr1 wrote:did you try shimming the master cylinder some (one of the bolts between it and the brake booster)?
that gave ALOT of clearance on my car between the turbine housing and master cylinder/brake lines.
Bowwwompchikibommbom...wikitiki...chikibowwow...Chezedik wrote:I have to work a party tonight...
