Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Mon May 17, 2004 4:25 am
i was ready to do this about a mont or two ago. from what i read that peoblem with going with such a large pipe would be the air velocity, or something like that, would change and not work to well. another idea would be to use a Y-pipe with the same size diameter as the maf and use 550's. what the hacked maf was first though of to use. im running 480's right now with a safc and z32 maf. even hacking the stock maf people like ::orion:: have it maxed out (5.1v) at 9psi, about 265rwhp. i think the hacked maf is great for 370's and lower boost but once your getting past 10psi, moderate boost to me, you should go with a better fuel system
