WDRacing wrote:Where are you located Bri???
Gainesville, FL
And while I'm a fan of seat of the pants tuning, the fact still remains that you couldn;t be 100% sure that the bypass would always pull the same amount of air...
i.e. say you set up a bypass tube and the A/Fs look good. Then you clean your air filter, and the path of least resistance for the incoming air is now more through the filter - You run really rich. Or quite the opposite, you install and tune, but over a few months your filter gets dirty - The path of least resistance is now more through the bypass - say it gave 37% more air before, but with a dirty filter you get 45% more through there b/c it's easier to pull air from the bypass = too lean and blown motor.
Only way this could work IMO is if you used a bigass filter with a oval mounting plate and plumbed the bypass back into that - So the air had to come through the same filter no matter which path it took, and there would be MUCH less deviation/variation.
Anyway, that's my take. We've debated this a bunch and the only way anyone has decided it's safe to run a bypass is if you run a Y pipe with two MAF sensors - One plugged in, one not. Then use injectors twice as big. Install new filters at the same time, and clean regulary to insure the split is even.
Later - Brian
