:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Tue May 04, 2004 11:00 am
Nope...
It's not a proportional increase like that...the cross sectional area is increased by 27%...that ups the metering capability, but not by nearly that much.
Mines maxes out at 5.11 volts at 9psi from a T3/T04E...about 255rwhp.
I was maxing the stock S14 MAF at ~7-7.5psi when I had the JWT ECU, and that was just shy of 240rwhp.
So if anything, it'll get you to the ABSOLUTE max of 370s, like my setup - Overun 370s at 54psi base fuel pressure, 9psi, and about 255rwhp.
(All numbers gained from using a Techtom CMX-100)
Later - Brian
