onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Nov 25, 2005 9:28 am
You probably didn't get any results because there's nothing to do .
H4 conversion is a simple plug & play, like replacing your headlamps.
Like Loveless said, you don't want those ****ty h4 lamps you linked to - pure crap. They will "look" ok, but the beam pattern is all ****ed up - believe me, I've bought nearly every h4 conversion option headlamp there is off eBay etc.
Currently, I'm running the Bosch headlamps, which have a much better cut off and pattern. You can also run the Hella ECE lamps. If you feel really baller, you can get the Raybrig ones. They cost more, but you will be much happier.
You can get the Bosch lamps from pdm-racing.com. You can get any of these lamps by checking out the guys in my sig - you'd have to AIM them, saw the Hella's at their shop, but they don't have it on their site yet.
