The reason why the color does not match is because you got the wrong color. 8000K is way too high and goes to bluish-purple. The most approprate color is 4300K which I have done on my car in the fog lights. Installation took about 1/2 hour and am very happy with the results.akliquid wrote:I installed HID H3 8000K bulbs to match my headlights. My brother did the install, but it was minimal customization. Removed the foglight and drilled a larger hole to fit the bulb housing. The socket part of the bulb was squeezed into the new hole and sealed with silicone. Ballast was mounted on top of the foglight. The brand I bought was called ONEX off Craig's List, but if I were to buy again, I would get another brand. Color temp is not accurate, and even my 2 bulbs have a slight different color. But overall very happy with the setup.
http://akliquid.myphotoalbum.c...it1_2
http://akliquid.myphotoalbum.c...heads
