its an exelent turbo , and under 500 brand new. h1c is a bit big as far as exhaust side and spool goes. What you want for ka is hy35w. Its same compressor side but turbohousing is only 9cm. And it hits full spool of 30-40psi on dsm's by 3500. So on ka by 3000. I 'll let you know exact rpm in a few weeeks hahah. (waiting for xternall wastegate+ new couplers and t clamps before it gets strapped in)
There is also a size up from hy35 to hx35 gets you a 12cm exhaust housing, i was reading people with oem dodges push those into 40-50 psi area.
to get you an idea on how h1c will flow look at Jeff's pull awhile back(30psi+ on ka24det using h1c)
http://filebox.vt.edu/users/je...e.jpgat 18psi he did 11's on the track
Modified by 180sx at 9:11 PM 7/27/2007
