naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Mon Jul 11, 2005 10:35 am
You may be sol, unless you have a huge understanding of circuitry. If it is on, then goes off after like 8 secs, then its prob not a loose wire, cause when a wire gets loose, the unit will work less and less, untill it finally stops working. You can always replace the cluster with a non hud one. It wont have the coolness factor, but they are more reliable.
