Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Thu Sep 29, 2005 7:26 pm
H&R spacers are the way to go. They are application specific and are machined to match the centerbore of the hub/wheel and have an extended center so the wheel can be aligned on it. I have some cheap *** spacers that don't do that. My car started to shake going over 80 due to the imbalance. Anyways, long story short, if you have to use spacers, H&R's are the ones. And you shouldnt need new studs for 5mm. anything over that and you will for sure.
