H&R wheel spacer question?
1WheelWonder
Car: 1991 Nissan 240sx
I am looking for 20mm wheel spacers and was wondering if the H&Rs came with longer studs or not, I can't seem to find a straight forward answer to my question. I don't need the type that bolt on to the existing studs and have new ones attached to the actual spacer, I can't think of a proper name for them. Just ones that can be used with longer wheel studs. Here is what I am looking at http://www.store.yahoo.com/pha....html . Any help with my noobish question will be appreciated.
nismofly
Car: 89 Nissan 240SX Hatch
youll need longer studs
nismo makes em
1WheelWonder
Thanks just the answer I was looking for.
nismofly
no problem
sleepyRPS13
Car: to sleep
h&r usually supplies wheel studs with the spacers
nismofly
everyone ive talked to has had to get nismo studs
maybe because its h&r
chmercer
the term you are looking for is "slip on" or "sandwitch" spacers. they are the kind that goes over longer wheel studs. the other kind are called bolt on spacers.
also nismo studs are crap, i suggest ARP
sleepyRPS13
Car: to sleep
what i was trying to say ont they include the wheel stud with the 5mm, 15mm ,& 20mm already with the spacer kit.except for 25mm cause its a adapter style.
chmercer
the slip on spacers dont come with new wheel studs, if thats what your asking. you have to get extended studs and put them on thoes. the bolt on spacers come with studs pressed in already, however.
sultan
i have 20mm h&r's and they do come with studs. they're really crappy though, look at the knurl length compared to stock and arp. i sold the h&r and used the arps. arp is slightly longer and they're gold so they're awesome.
BaliLover
The ARPs also require that you get a new set of lugnuts since they are a different thread pitch than OEM.
chmercer
yikes @ the h&r knurl, lol
teddy
Car: Saab Turbo and MR2
He said knurl
sleepyRPS13
Car: to sleep
why is it so thin and small?
chmercer
sleepyRPS13 wrote:why is it so thin and small?
because its *****y? lol. get arp studs
(man this profanity filter is whack. it used to just star out the words, now it just totally erases them)
Modified by chmercer at 6:48 PM 2/4/2006
Red coupe
Car: 92 Nissan 240sx Coupe
? it still stars them out... see ****
chmercer
type f u * k out 3 times, i had to edit the stars in on that last post
40daws
Is/has any one run the extended Peak Performance studs ?
chmercer
friend runs them, they are fine. way overpriced though.
