Grant@tirerack wrote:Serious drag racing would require a totally different spring setup than you will find with these street setups. They would have to be a drag-specific spring setup to handle the weight transfer and axle torque issues involved. I would check with a local race shop or contact one of the spring makers direct for the correct setup.
Grant the spring rates on either of the lowering springs are no where near hard enough to make a difference on a drag launch. It's a different story with the coilover sets but with normal OEM style springs you can't really get a spring thats too hard for drag.
The problem you face with alot of weight transfer on a Nissan is the distortion of the contact patch by the resulting camber change. If you drop 2" in the rear on the launch you've created nearly 2 degrees of negative camber. This in turn can cause nearly an inch of your contact patch to decrease. This is one advantage solid axle cars like the Camaro have over us.
For a proper launch you'll want some sort of camber correction device in the rear to set your camber at either + 1 deg. or 0. For streetability I'd suggest 0.5 deg. negative. Positive camber makes the rear end VERY loose (meaning uncontrollable) but will insure that when the car does squat in the rear that you have the full contact patch on the ground.
Your gonna want something like a:
5 / 3 setup on the spring rate.
The numbers represent kgf / mm ... meaning it requires X kg's of force to compress the spring 1 mm.
