rightFGFCacoupe wrote:So if I want the car slightly lower than on the Eibachs, my performance wont change. Thats good to know.
All good points Blake!adidas2go wrote:
right
the lower center of gravity will give you better performance all around. Acceleration because your wheels wont hop or travel as much, Braking because your front end doesn't dip as much and doesn't throw your momentum forward abruptly, and Handling, well i think thats pretty obvious, thats what the springs are designed for
Or,...you can be like some of the teenage ricers around my area and save yourself a couple of $$ by torching off the bottom section of your OEM springs then re-installing it But I wouldn't recommend that
As for me, performance is key as I'll be autocrossing the coupe.adidas2go wrote:
right
I'm no expert physicist, but 1/4" is a lot in the world of physics. I agree; lower front end and a higher back end is the way to go.adidas2go wrote:1/4 inch lower in the rear isn't going to adversely affect your performance in the least though
