H&R spacers question?
toledo240
I need 15mm spacers to clear my z32 brakes. Now i heard the H&R spacers come with studs, but are they extended? its m12x1.25 which is the same as stock.I need extended ones so do i got to get nismo studs? also should I do the spacers in the back to? I was think 5 or 10 mm in the back to even it out with the front a little
WongFeiHung
The bigger H&R spacers/adapters bolt onto your hub and have their own studs, u wouldn't need aftermarket studs unless your were going to add additional spacers on top of them...they are hubcentric so u can't go wrong with those...
toledo240
do you know how long the studs are? are they longer than the oem bolts? by how long?
WongFeiHung
Why would they need to be longer? The extra set of lugs is built into the H&R spacers...If for whatever reason they are not long enough, u can replace them...
Jookmasta
how much did u pay for the H&R spacers and where?
WongFeiHung
I don't have them but you can get them from http://www.optauto.com
toledo240
i ordered mine from there i paid 160 for 15mm pair and a 5mm pair. and shipped across the country with three day shipping
Dystopia
Car: Nissan S13
http://www.tougefactory.com has some nice spacers
