dangeris »
https://forums.nicoclub.com/dangeris-u76570.html
Tue Jan 27, 2009 10:54 am
Lets keep in mind when dropping our cars is that one of the reason why guys are going with the Eibach kit is because you don't need to mess with the camber...or should I say, a camber kit is not necessary. When you drop the car, you're essentially lowering the center of gravity of the vehicle; thus the tires will tilt in. If left alone, you'll go thru tires like nobody's business. IF you drop it too much, you'll need to buy an after market camber kit for both front and rear which is an added cost, not to mention the installation cost too
