H E L P ! ! !
GodGuy_240SX
Car: 93' Nissan 240SX SE FastBack
I just want to know if it's OK to REMOVE THE FUEL TANK VACUUM THAT GOES TO THE CARBON CANISTER ???(and remove the little solenoid called fuel vheck valve too)...Will this remove my gas tank pressure and will it be bad ?????? There's gas coming from this line into the canister and I changed my check valve and gas cap but nothing changed... I'm building too much pressure in da tank!!!Thanks !
navysnail
how do you know you have too much pressure? if you did, your gas cap would be at fault, even if you did check it. did you have an emissions place check your cap?
