PantherRacer »
https://forums.nicoclub.com/pantherracer-u15735.html
Thu Feb 22, 2007 4:29 pm
Yeah. Now that I have your attention.Is the problem my injector? I noticed the motor was missing, and I told my boy (mechanic). He dismissed it as the motor mounts (which are bad and DO need changing, but another story). But upon pulling the injector plugs, cylinder #4 has no effect. Pulled the spark plug for the cylinder, it's black. Cleaned it off, put it back in, no dice. Motor still misses. Cleaned the CAS just in case because it has a broken cover and that might've been the problem, nope, still misses. So I figure it's the injector, since the wires are all grounded to the same spot, you know. It's also been backfiring a lot yesterday, and it died on me while I was waiting for the idle (which was super low) to even itself out.
