Guys please help
Post all your Nissan electronics, car audio and stereo questions here!
xoutlawz00x
im installing a low output converter to a 95 nissan maxima with bose and i cant figure out what are my rear speaker wires and when to hook the loc up too.. please help thanks
PoorManQ45
HOwdy. Glad to see that you found the place alright
Can you check your rear speakers for me. Is there a black "pod" looking thing on the back of each one?
xoutlawz00x
can i check trough the trunk or i gotta take something apart inside
PoorManQ45
Through the trunk. There may be a carpet divider or something like that. Easily removable
xoutlawz00x
ill try and check now its dark out
xoutlawz00x
yea each speaker is connect to a black kinda thing that covering it
PoorManQ45
Does it say bose? If so then that's the bose amp.
You can use the speaker wire outputs from each amp to send a signal to the amp(s). Of course you're going to have to use a line level converter.
xoutlawz00x
i dont think it says bose but the speaker is connected to the black box. and the black box has a kinda silver box inside of it
PoorManQ45
K then, that's the bose amplifiers, one per speaker.
Do you know if your car has a powered subwoofer stock? If so you'll want to put the LOC on that signal.
Wait, what are we doing here again? Are you installing a sub amp or an amp for the mains, or both?
If it's for the mains then you can install the LOC on the speaker wire that goes from the bose amplifier to the speaker.
xoutlawz00x
adding a loc to add a amp for seperate subs
PoorManQ45
k then.
So you want to keep the bose amps/speakers too?
xoutlawz00x
yea
Florida240sx
Wow I'm lost on this thread...Usually I can help but...well glad PMQ gots it.
Common mod.
I'll be doing the same with my Q soon.
You tap into the low-level leads for the rear speakers for signal, and add a powered sub (or an amp and sub).
Carry on!
PoorManQ45
Nope, the signal going to the bose amps isn't the same as an RCA signal is. So you can't just slap a LOC on it
YOu want to tap into the high level leads(speaker wire). Much "easier" that way.
audtatious
Hopefully, this will help you with the wiring:
http://www.moodym.com/maxima/a....html
The '95 Maxima had individual Bose amps on each speaker...
