NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Oct 10, 2003 6:38 am
this is a very common occurance on the altima. have seen it personally a number of times. you should be able to rethread it in. if it wont go in due to buggered up threads in the head. take an old plug and use a die grinder to cut 4 slots in it running the length of the threads. you will basically be retaping the hole without all the large metal flakes getting down in the cyl. then remove it and install a good plug and torque to spec.
