zerothread/358025
Exhaust vs Compression top dead center
The easiest way to know that your top dead center is compression tdc is to observe the postion of the rotor by removing distritbutor cap. It will be pointing close to cylinder one on the compression stroke and close to cylinder 4 on the exhaust stroke. This, of course, only works if you distributor timing is in the normal range. If your timing is really off, you will have to place your hand on the sparkplug hole(sparkplug removed) and feel the pressure build up on the compression stroke as you rotate crankshaft by hand.
alternativelyNote here the position of the cam lobes on #1 cylinder. They are facing outwards which means its at TDC on compression stroke. If the #1 cylinder cams are facing inwards then just rotate your pulley another 360 degrees until they are facing outwards.
