Guys I need help asap!
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
As some of you know I just moved and I dont have internet where I live yet. So I only have it for a couple hours tonight.
Problem...My S13 took a huge s*** on me yesterday. It cranks but doesnt start. When I had it running, while idling it felt like it was going to die. I figured it was just a vacuum leak. Well as of yesterday when I hit the gas it would like sputter real bad. Finally at a stop sign 2 blocks from my house (thank god) it dies and will not start. I have checked almost everything I can think of. I checked the MAF sensor, fuel pump, fuel filter, spark in all cylinders, crank angle sensor, and the distributer cap. Everything checks out fine.
I have a KA24E Thanks
xekushnr
Car: '90 Nissan 240SX Hatch
So have you checked fuel pressure while cranking? Coolant temp sensors can cause a no start, and a bad TPS can cause most of those symptoms but I'm not sure about a no start. Check them out though.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Got fuel in the tank?
Razi
Car: Moo
Yeah, check the coolant temp sensor, once mine went bad and made it hard to start.
Also check your fuses and fuel injector o-rings.How's your air filter?
Xdisaster240sX
Air filter is fine. I'll check the temp sensor and o rings in the morning. Thanks everyone!
S13_love
Razi wrote:Yeah, check the coolant temp sensor, once mine went bad and made it hard to start.
krash
Reverend D wrote:Got fuel in the tank?
Happened to me this morning, sounds like the exact same symptoms
Kelbizzle
Car: 91 240SX SR20DET
It happened to my friends this morning with his 87' 300z as well. The first injector on the left side was saturated in fuel right underneath the FPR by time I came out to help him. I didn't even look into it. He's been neglecting an intermittent starting issue.
It must be this rain huh..What are the odds of a rainstorm coming to MD and knocking out 3 Nissans in a matter of 24 hours?
Dattebayo
It's a bad fuel pump most likely. Why is this in Gen Chat?
Kelbizzle
Yesterday I took a look at my friends car. I figured out it was his Distributor cap and rotor. His rotor was pretty much rusted down to nothing. Here are pics.
Taidje
HI ! your car has come really big problem this cause they are not start so just check a good mechanic , i hope they solve solve your problem .
seang
Car: Ford Fiesta ST
Taidje wrote: so just check a good mechanic , i hope they solve solve your problem
We are more speshul than mikanicks.
AZ89two4Tsx
Pull the valve cover. Takes like 5mins. There's like 8 5mm bolts.
Same kinda issue happened to me. I thought I threw a rod, but it ended up being a retaining clip that holds on the rocker arm.
Again, pull the valve cover. That could be it.
Taidje wrote:HI ! your car has come really big problem this cause they are not start so just check a good mechanic , i hope they solve solve your problem .
Cool story spamfag.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It's nice of him to link to NICO in his sig, but I'm not sure what it has to do with Audi A6s.
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
Well, he is from texas california....
Dattebayo
AZ89two4Tsx wrote:Pull the valve cover. Takes like 5mins. There's like 8 5mm bolts.
Your issue was a fluke, midget.
