AznRide »
https://forums.nicoclub.com/aznride-u2577.html
Fri Feb 27, 2004 6:12 am
When starting the car, he has to give it gas else it won't start and even then sometimes it takes a few tries.
Check the battery, may not have enough sparks to even start the car, check your wirings by the ecu or where he had his wirings modded. Make sure there is no exposed or discconected wire. Happened to me once when I was driving, my car would shut on and off...weird, and when I stopped, it cranked, but won't start. When I looked at the ecu, there was a wire that was loose from teh connection. Hope that would help
Gonna hook up a voltmeter to the MAFS. Anybody know a voltage to look for at idle? Im assuming around .2v or something?
Because it idles smooth, I have to assume that the coil packs are good. Is that a fair assumption? - This is your solution. If the MAFS is bad, your car won't run well. Meaning of that is that it won't let you rev pass 3500 RPM, but nevertheless, nothing to do with the car has to get fed by gas before starting.
I hope that help, if not, some other members will definitely help you with this
