Guys help me with these staggered wheels!!
Mr_Coupe
Car: 08 Code Red 6 speed manual transmission 3.5 v6 Altima Coupe
i got some new wheels for the summer but im having a problem getting tires so blake, dangeris, and everyone else do your magic!! my wheels are 19x8.5 and 19x9.5 can someone help me find the tire sizes for both that will fit thank you i owe u guys!!!!
PS: i know this is suppose 2 be in the rims and springs section but the coupe area gets more people
Mr_Coupe
come on so no ones gonna help me
h8ncops
Car: 08 nissan altima coupe
look on wheels next u should be able to pull up the rim combo u have if anything look up 350z and get tire rim combo they will show u what size
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
9.5=issuesno one can help bc no one has it
h8ncops
here ya go front 245/35/19 rear 275/35/19 hope u have plenty of money they cost some serious money prolly more than rims
Mr_Coupe
finally! thankx tho guys i know its an issue but i wont worry about the money cuz ive been saving
Loop
Car: only nissan cars
Few options you can do, they will fit on your wheel size, but I don't guarantee it will not rub. If it does rub, you can do fender rolling/cutting and camber adjustment if needed. I can tell you better if you list your offset and what lowering kit you will be on.
Staggered Tire Setup:Front: 235-255/35/19, 225-245/40/19
Rear: 265-285/35/19
More common setup is 245/35/19 Front and 275/35/19 Rear
Or
You can simply get same size on all 4 courners, something like 245/35/19
Mr_Coupe
loop the offset is 35
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
If you are worried about rubbing, get a narrow tire for the rear wheels. Nothing wider than 245mm (9.5 inches = about 241 mm), so you can stretch it onto the rim and have less of a chance of rubbing. Something like a 225/35 for the front and 235/35 for the rear.
Mr_Coupe
so u think a 245/35/19 front and a 275/35/19 rear would rub ima lower it on ebiach springs and i know a lot of u guys have em on here.. i need the best size that will fit good and make the chance of rubbing slim..i didnt get mine yet cuz ive been working on getting an apartment ...
Mr. Music
With a +35mm offset on a 9.5 inch wide rim, I wouldn't run a 275mm wide tire, as it will probably rub. If the rims were going on my car, I'd run a 225/35 front, and either a 235/35 or a 245/35 rear; but a 235mm tire might be too much of a stretch for a 9.5in rim, but I'd talk to the tire shop about that one.
Mr_Coupe
yea but there is a guy with 20x9.5 rears on this forum and he has it wrapped in 275/35/20 and he doesnt rub
Mr. Music
I don't think that car is lowered though. I'm not 100% sure if it is or isn't, but if it is and he doesn't rub, then you can pretty much put anything you want on there.
Mr_Coupe
thanx mr.music ill see but ill probably just take ur advice and see if they can strech it on to the tire.. thanks for the help
