- Seatbelts are there for a reason! Use them!- Street racing/drifting is like playing Russian Roulette. It is not a matter of IF you will get hurt/killed...it is WHEN. Not to be sadistic, but Russian Roulette at least only puts you in danger!! Remember that!- Check your tires every time you fill up! Crappy touring tires can literally wear out seemingly overnight. If you pull from a stop and don't even romp on it and you lose traction in the wet, get new tires! (those of us that have Falkein Azenis need not apply)- Learn car control. You may think you are Keiichi Tsuchia, but you aren't (not an insult to you guys that are;)) If you think that something would be bad *** to try on the street, it is probally illegal/dangerous. -Don't just mod your engine! The faster your car gets you going, the less able your stock suspension/brakes/chassis is able to cope with the power. Plus, you get to add stuff to your sig;)
Mods: I think we should (as a community) make a concerted effort to keep threads that condone dangerous activities to a minimum.
