Assembled -
Disassembled, top 4 layers -
Disassembled, bottom 3 layers (the part on the left is the 4th layer from previous photo) -
It seems to me that the mode of failure is the solder that holds the resistor between the two terminals melts away
due to heat cycling, causing the sensor to read increased resistance, lose continuity, or short together.
Just in case anyone was curious (Paul...)
