evildky wrote:because they don't, the stock TT passanger side turbo feeds the passanger side of the engine, and the drivers side turbo feeds the drivers side fo the engine, and there is a ballance tube on the intake to smoothe out any difference and there is an H in the exhaust to smoothe out any differences there
a lot of swaps use goofy crossflow intercoolers taht are less efficient than stock and route the piping across otherwise it should be same side routing, as for engineering it's all about airflow , the shortest smoothest passage wins, vertical flows are generally more efficient than crossflow, ricers don't get that
Ummm... Go back and look at your car again. Yes they do. the stock passenger turbo feeds the passenger side throttle body. But the passenger side throttle body feeds cylinders 2, 4, and 6. Cylinders 2,4, and 6 are the driver side cylinders. Vice-versa for the driver side turbo.
I do believe the literature of the time said it was to help equalize any potential differences in turbos and better balance the engine power. So that if one turbo was boosting slightly more than the other, that extra boost would be supplied to the weaker turbo and balance the power distribution across the cylinders. Naturally, the balance tube is supposed to help equalize it, but if there is a significant difference (like a wastegate failure or something), that little tube could not handle a 14psi difference.
