rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Sun Feb 20, 2005 9:51 am
GReddy radiator hose adapter, electric gauge Autometer #4355. The igniton wire is wrapped around a fuse in the fuse box (ghetto fabulous). The ground is going to the ground on the head (the big 8g wire that comes from the fuse block at the battery tray) and the signal, of course, goes to the signal wire. The first time I hooked it up, I think I had the ground and signal backwards, because it instantly went to full hot. Now, it seems to work just fine. Note: I am 100% sure that it was the ground and signal that were the wires in question...I made sure and kept the switched igniton wire under tabs at all times.
And to note: the gauge does read in farenheit FYI.
