rpm240sx wrote:So, how did this project turn out? Were you able to keep the voice?
While the post is old what I feel is missing is that the nav voice seems to be a balanced output which is applied to the stock amp for use for the right and left front channels, at least based on the FSMs I have looked at. To work correctly and to protect the nav unit these probably should be isolated from the new after market amps rca style inputs which have one side grounded.
Here are a couple of links to explain this:
http://www.allaboutcircuits.co....html
http://www.installer.com/hilo/
http://www.installer.com/item/...SVEN4
http://www.installer.com/item/...SVEN2
http://www.installer.com/item/...SVENR
The first will give you an idea of what opto-isolation is about.
The rest have descriptiosn that are not as detailed as I would like but seem to point to what is contained within them. That is they speak of balanced inputs which is what the nav appears to output and of isolation between the in and out.
Another thing to look at would be a headphone preamp. Some of these are designed to take multiple inputs and put out one output and are differential amplifiers using opto-isolators.
So from what I see, if the 2 channel version about that speaks of balance to unbalance basically what you most like would do would be to connect the input side to one of its input channels and use one of the outputs to your new amp. On the input side if the negative side of the input is in fact isolated from the outputs rca ground side and also the ground connection of the device then it may well be a packaged unit for what you are looking for.
I would suspect that Car Toys or maybe even Best Buy actually has something similar but I also suspect many of these types of shops really don't understand them. They work for connecting factory head units which use an external amp to an after market amp of your choosing and that is what they understand. The next time I am at one of these shops and maybe RShack I will take a look as I have a project of my own I am considering.
But in the case of the nav voice you are in front of the total audio connection which has also combined cd changer and other common car audio signals which is slightly different.
Perry
