Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Wed Feb 15, 2006 12:29 pm
The best way is to use a ball hone, but they are notoriously difficult to use if the motor isn't in a fixture. To get it done right, you will likely want to take it to a shop (plus the hone sets are pretty pricey).
EDIT: I would use antifreeze rather than brake fluid if it is a KA block, but I think the idea of you turning a drill and taking off enough material to make that necessary is a bit lude.
