Guide or removal instructions for 95 S14 ECU?
Lucky736
Anyone have a guide or instructions? I need to runt he diag mode and reset the ECU. Pls let me [email protected]
I need to know how to physically get to it. IE what to remove to get behind the kick panel where I believe it
MYK
Car: 1995 240SX SE, 1997 GTI-VR6
Lucky736 wrote:Anyone have a guide or instructions? I need to runt he diag mode and reset the ECU. Pls let me [email protected]
did you ever get this? if not, pull up the sill panel, just pops off. The there is a 10mm plastic nut on the kickpanel towards the firewall. Pull that out, then te kickpanel just snaps out. It has two clips on the front by the edge where the door is. Try to pull it straight out (towards the center of the car) might be kinda tight if it has never been out. The ECU is right behind there. Three 10mm bolts and you can pull it out, one towards the firewall, one at the base of the kickpanel behind the harness, one at the front corner of the dash. Pop the ecu harness out of the plastic holder that is attached to the ECU so you can move it around with ease. The pot for the diag is on the back side. I wish it was just on the front side so all you'd have to do is pull the kickpanel and not have to unbolt the ecu. would be a lot easier
