so says the man who swapped his in and used the same timing belt and water pumpKamin wrote:to do it properly wich means new clutch, timing belt, water pump, etc your looking at around 5000$ to get it in and running well.
says the man who overheats on track even in 60 degree weatherkrayton wrote:so says the man who swapped his in and used the same timing belt and water pump
